Results 1 to 9 of 9
Thread: WTB: 380MM wheel...
    WTB: early batwing..
    I have sourced the 380mm wheel I was looking for and a puck and hardware...still looking for a batwing core. Thank you.
    Oct 2018
    Orange County, California
    Recommend the 805.10
    1957 356A Cab Condor Yellow
    1970 911E Targa “CONDA G”
    1970 911T3.2 “Meatballs”
    1972 911T2.5 “AWBRGN”
    1972 911T Targa Glaserblau
    1976 911S Talbot Yellow
    Jul 2011
    Chicago Area
    I have one available will post some pictures later tonight.
    Mike Fitton # 2071
    2018 911S Carrera White
    It may not matter since it is changing the stock one for one not found on the car but isn’t suffix 806.10 the only one of that 38cm size mentioned in the factory parts book model 72/3 ?
    Oct 2018
    805.10 and 806.10 are identical. 806.10 is specifically attributed to 73 RS and will command a substantial premium. The 805.10 is plug and play; no fitment issues. Other models will work but may be a bit wobbly. There is an extensive and very informative thread about 380mm wheels. Best of luck
    Quote Originally Posted by Cruisingnkali View Post
    Thank you for the additional information, and yes, no need at all for the RS 'premium' wheel for my application.
    BUMP for batwing...thank you
    Jul 2011
    Chicago Area
    Quote Originally Posted by mac73s View Post
    I didn’t think a batwing fit on a 380mm wheel?
    Mike Fitton # 2071
    Quote Originally Posted by mfitton View Post
    I got the idea - and liked the look - from a friends 72 911T. He has the same 380mm 914 wheel and it works fine.
