Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: this is odd, SWB steering arm question?
    Back to the original question , all tie rod end ball joints are the same , the difference would be the steering arm . There is no way the original ball joint fit one way and the turbo fit another way in the same arm unless one is / was upside down and improperly installed .
    Senior Member Fubawu's Avatar
    I can't say how the original fit, it was a worn stock rod.
    I found this odd on a well prepped race car. I was just curious if there was another steering arm option. I measured the taper and it seems to be reverse.
    Does anyone have one and possibly measure the taper?
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
    Dec 2018
    Gilbert, Arizona
    Note sure if this will help, but towards the end of my video on rebuilding the front suspension on my 1967 912 you can see the steering arm and how it attaches to the tie rod end. Hope it helps!
    https://youtu.be/vYzZyMg873s
    Brian
    Thanks Brian
    yes traditionally the arm enters from above as it has to match the taper of the arm. For some reason my arms taper is opposite. Or at least I think it is, does
    anyone have an arms they can measure the taper on?
    911 1967S 308470
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
