Thread: Glovebox switch wiring
    Jun 2018
    Sydney, Australia
    Folks, what path does the wire that goes to the glovebox switch take? Mine's missing completely. I know it needs to come back to the light, but I can't see an obvious easy route even though they are literally beside one another. Why there isn't a simple hole in the sheet metal there astounds me..
    Hoping I can hook it up without having to remove the HVAC..
    '95 993 | '70 911T
    There should be a brn/whi wire coming from the 6 pin bulkhead connector that feeds the fresh air blower. If the car has been apart for restoration all bets are off. Wires don't just disappear.
    Jun 2018
    Sydney, Australia
    Thanks Ed.. the car has been apart yes.
    '95 993 | '70 911T
    Jun 2018
    Sydney, Australia
    Glovebox light now working via switch. A PO had cut the brown/white wire and taped it up... 🤷
    '95 993 | '70 911T
