Thread: MFI Fuel Lines
    Feb 2010
    San Francisco, CA
    MFI Fuel Lines
    Seems like it's probably time to R&R some of my fuel lines for the sake of safety. It's been ~11 years.
    Does anyone have experience or knowledge of the hard/soft line combo that has popped up on PP, Stoddard etc?
    911.356.064.08 https://www.stoddard.com/91135606408.html
    It's got both the hard line that goes through to the engine compartment & the soft line to the pump and T-splitter attached. Is this a better option than the usual Norma clamps and splitter?
    Thanks!
    Kent
    E911SR & RGRUPPE
    '73 S Coupe #306
    mechanically the O.E. crimp and the clamp would work the same, I prefer the look of the O.E. crimp however. I've used the replacement line you mention,,,works just fine.
    Feb 2010
    San Francisco, CA
    Thanks as always Ed.
    E911SR & RGRUPPE
    '73 S Coupe #306
