Thread: S-trim bumper rubber - Same for F & R?
    Aug 2011
    Eugene, OR
    I'm finally about to replace the original rub strips on my bumpers. Wide S-trim. Looking at one-piece front, and noticing that a pair of pre-cut rears are considerably more than just getting a second front part and then cutting it to fit? I'm pretty sure the profile of the rubber is the same, but are the rounded ends and the stud locations the same as well?
    - Arne
    Aug 2017
    el sobrante ca.
    yep .... the same .... Eric sells them.... you buy one for the front and a second one that you cut in two for the rears...
    Or ...I should say .... Eric's rubbers have a continuous channel that you slide the "studs" into what ever location you need...
    Mar 2016
    U.K.
    Quote Originally Posted by Arne View Post
    That is exactly what I did. I ordered two front rubbers and cut one for the rear.
