Thread: Under Dash Multi-Pin Connector Locations
    Hi all,
    I'm replacing my blinker/flasher combination switch in my 1970 911E. I removed several multi-pin connectors to get it removed and now after a couple of months, I'm reinstalling everything and I'm questioning my notes on what goes where. I'm hoping some might be able to give me the order of what goes where. Looking at the wiring diagram, I don't believe it shows the order, left from right, on what goes where.
    From what I can tell there are (5) multi-pin connectors under the dash. Starting from the left, you have the headlight and emergency flasher. It's the final (3) that I'm questioning. Is what pictured below correct?
    Chris
    Yes, that is the correct order as in your photo.
    Turn signals then wipers then ignition.
    Thanks!
    Chris
