Results 1 to 10 of 13
Thread: captive nuts for door pockets?
    Jan 2019
    SF Bay Area
    hey folks, I was wondering if anyone might have a part number for the captive nuts that are used to secure the lower edge of the door pocket to the door (circled in red in the picture). as you can see in the picture, my car used to have these, but they've gone missing after the car was painted :-(
    it almost looks like the part should be a flat plate with threaded holes, but I wasn't able to find a separate listing in the parts catalog unfortunately. thanks for your help!
    Nikhil
    Member #3857
    '70 911 2.7
    These captive nut sets are spot welded to the door frame...very, very confident (which your research confirms) they are not a separate part that can be ordered from PORSCHE. I will follow up with a photo of what I used...believe I purchased them from McMaster-Carr..drilled the old ones out and spot welded these in where needed.
    Quote Originally Posted by mac73s View Post
    Here are a few photos...
    Jan 2019
    SF Bay Area
    thanks, mac! I'll look into the options from mcmaster-carr (https://www.mcmaster.com/cage-nuts/). I guess a rivnut might also work--my car is a hot rod, and the door panels are "RS" style, not original.
    Member #3857
    '70 911 2.7
    Aug 2011
    Eugene, OR
    A riv-nut may work, but might not be ideal. The original captive nuts float a bit to allow some tolerance for inconsistencies in the paperboard door pockets. Fixed position riv-nuts might be difficult to get everything lined up.
    - Arne
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by Lz7w View Post
    Nikhil
    They should be on the INSIDE of the door where you have circled. The 'rectangular' marks you equate to a 'plate' are from the plastic door pocket hinges. That's where they mount. I'd be surprised if the captive nuts are actually missing. Usually when installing RS panels, a couple of the lower existing captive nut locations are selected for attachment.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
    Curious to know - if you are doing RS style panels (assume without the original door pockets), why are you concerned about these captive nuts?
    Quote Originally Posted by Arne View Post
    +1 With a rivnut you'll lose the ability to align the door pocket with the bottom edge of the armrest.
    May 2014
    South East USA
    Riv-nuts that 'float' are available.
    Maybe not that small. But we use them in aviation industry.
    Jan 2019
    SF Bay Area
    only because the panels came with instructions saying they should mount with machine screws (that go into those captive nuts). but I should also be able to switch to a self-tapping screw for mounting (which, as I understand, is more like the real RS panel anyway).
    Member #3857
    '70 911 2.7
