Thread: which clamp for '73? Norma or Gemi?
    Senior Member swisscheese's Avatar
    Jan 2003
    The Netherlands
    folks, unfortunately, I've lost a number of clamps, so in search of "new" ones, I'm in doubt which type they shoudl be:
    For the large vent hoses. the parts manual gives 999.512.128.02 (new number 999.512.349.02 (50-70 x 9mm). Should be a Norma or Gemi?
    Name:  vent hoses.jpg
    I've seen two options for th 50-70:
    Either Norma:
    Name:  norma 50-70 ct.jpg
    or Gemi:
    Name:  gemi 50-70 ct.jpg
    For the clamp on the sleeve, the manual gives : 999 512 181 02 (57-76mm x 9mm):
    and the two clamps from the aluminium flexhose to the heat exchanger on the regulator; manual says 999 512 348 02 (38 - 58mm X 9mm)
    thnx for info.
    911S 1973
    Early 911S Registry #176
    All original clamps were Gemi, I don't know if they are available new anymore, at least not that I've seen.
    Peter Kane
    '72 911S Targa
    Jan 2003
    The Netherlands
    thanks. but it seems all of the ones I have are like this:
    Name:  Gemi close-up.jpg
    911S 1973
    If u want original, right side clamp in first post is it. Just not available new anymore. The hoarders got to let loose of them. Post #4 is correct. Clean them, re-plate and your good.
    Jan 2003
    The Netherlands
    re-plating not always a success..
    911S 1973
