Results 1 to 2 of 2
Thread: 915 diff drive flange end play
    Folks
    Just checking if this is normal, the drive flanges on my 915 diff have a bit of lateral movement, i.e. they each slide in and out about 2-3 mm in the the diff casing. I have disconnected the drive shafts and the flanges are fully bolted up onto the diff pinions. There is also a bit of movement of the flanges up and down when pushed from below the car, with the left side having about twice the movement of the right, the diff casing itself is not moving, it's just the flange.
    Thanks in advance
    Mike
    Cheers
    Mike
    Movement is normal and not always symmetrical
