Thread: Rear seat Install hardware help
    Dec 2013
    Connecticut/Florida
    Hi all,
    I have searched and can't seem to find much on this - and for some reason I am not certain on the correct sequence. I have a picture from that PET and I have shown below that parts I have. Can someone help me understand the sequence and side which these parts go in correct order for the seat bracket? I also have two of the rubber triangles shown at the bottom.
    1971 911S Coupe - Gemini Blue
    Dec 2013
    Connecticut/Florida
    Someone is an expert on this ! Please ……..
    May 2006
    CT
    Simon
    If you look at the 74-77 PET it gives the P/N's for these pieces.
    #3 obviously is the shoulder bolt
    #4 n 012 230 1 is the B10 spring washer
    #5 901-522-509-20 is the plastic bushing
    #6 999-591-111-50 is the rubber washer
    #16 901-522-365-20 is the plastic washer
    The order of assembly is as shown in the diagram and you can google the P/N's to match the images to the pieces you have. Pictures worth a thousand words.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Dec 2013
    Connecticut/Florida
    Thanks Tom. Do any of the parts go on the inside of the seat bracket - against the carpet? Or they are all on the outside?
    May 2006
    CT
    If I remember correctly, I installed #6 between the seat bracket and the carpet.
    Tom Butler
    1973 RSR Clone
    1970 911E
