Results 1 to 8 of 8
Thread: Wire Question ?
    Wire Question ?
    ftorchia.aia@gmail.comGuys
    Been reviewing the 70 & 71 factory wire diagram .
    There is a solid black that comes from the turn signal switch /wires .
    It shows on the 70 & probably before but on the 71 version it’s not on the diagram ?
    Anyone with 71 or look below to see what happens to this wire ?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Sep 2018
    Netherlands
    In the '72 diagram that I have, the 53c solid black wire is shown on the second part of the diagram. Unit 30 is simply divided between two pages.
    1970 2.2S Elfenbeinweiss
    2002 996 TT Midnight Blue
    Member #3833
    May 2006
    CT
    Frank
    My notes from my '70 build show the black wire on the T/S switch is the feed to the washer pump and connects to the wiper washer switch.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Tom & Frederic
    Thanks for followup…..Tom the factory wire diagrams also suggest the same coming form 53c to a connection then to the wiper motor, but there are no loose wires coming from the wiper switch all in casing to end plug ?
    Anyone have an opportunity to look under dash
    Thanks guys
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    What is the problem you're having? And which car is having the problem?
    Ed
    My 71 …installing electrical items after restoration.
    New harnesses etc.
    There is a single black wire from turn signal unit/wires and don’t see any available connections for the wiper switch.
    The wire diagram shows a single pole connector for that wire that then goes to wiper motor .
    The photo shows the black wire
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    May 2006
    CT
    Frank
    My original answer to this does not help for a '71 car. The 1970 wiper system in one year only. That wiper switch has a black wire that connects to the black wire from the T/S switch. The '69, '71-'73 wiper switch does not have the black wire.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Tom
    Think at some point the wiper switch may have been changed so maybe it’s a later version.
    Will go to the wire at end connection to the wiper motor and probe the contacts on the body plug to see if I get a contact .
    If so then this wire is not used .
    Thanks again
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
