Thread: 73 Trunk carpet front piece
    The Netherlands
    I am pretty sure that most of our cars are missing the front, slam panel, carpet. The right side front of my 73carpet was eaten by time (48 yrs) and acid, using the original front as a pattern I did cut out this piece. Hard to put a price on it, how about € 10,- plus postage. To the US I hope it will be not more than €11,-, could be € 23,- though depending of the box size.
    Best,
    Cees
    What is the correct way to install this piece, or how are people doing it? I assume it should be glued in, if so with what? Reluctant to commit to gluing, so mine just floats around. TTT
    Dave Reu
    Member #3949
    1973 Silver Metallic 911S
    The Netherlands
    Glued in originally, like a dome looking from above. Don't know if that makes sense..
    Cees
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    I used wide black Velcro on mine. Stitched one piece to the perlon carpet, and attached the other piece to the body with Command strip. Been there for 7 years, no problem.
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    The Netherlands
    For free, except postage. NLA, on it's way to the Germany.
    Cees
