Thread: Beru Spark Plug Extensions
    Hello to All
    Could anyone please advise me of a part number &/or supplier for the threaded crimp-on spark plug lead for a Beru spark plug extension (from a 1970 2.2L engine) as per this photo:
    Name:  Plug Wire - Threaded.jpg
    I also need a replacement part number for the accompanying extension as per the photo below to suit the same threaded crimp-on plug wire end. The type offered by Pelican & ParstKlassik et al. seem to be of the “wood screw” style of end fitting. I have 5 in good condition & re-useable ones but I require a replacement for the damaged extension compatible with the crimp-on threaded end.
    Any info or advice you can forward to me will be most appreciated & helpful - Thank you in advance.
    Cheers
    JB
    Success is not final, failure is not fatal: it is the courage to continue that counts. - Winston Churchill
    Early 911S Registry Member #3749
    We get the crimp ends from Wurth. The "wood screw" ends are the original type used on your car. Try "Kingsbourne" should have what you need.
    Hi Ed
    Many thanks for the "heads-up". A humorous side note - in my search for "Kingsbourne" - I had a bit of a time trying to avoid a real estate developer's website flogging homes in Cheshire in the north west of England - finally met with success.
    Once again, thanks for your help Ed
    Cheers
    JB
