Results 1 to 7 of 7
Thread: Protect Headlight Switch & Dashboard Circuit
    Jun 2003
    Bend, Oregon
    I'm not sure that everyone knows that the supply lead for the dashboard illumination is not fused - which could be expensive. A short in a brass bulb holder can lead to damage in wire harness, including the expensive headlight switch. It's an easy thing to remedy. Place an inline fuse at the headlight switch in between terminal 58A and the black blue wire (except '69-'70 which are black-purple).
    You can do it yourself or buy this inexpensive piece by Kroon at the AC Shop with correct factory wiring):
    for $18.50.
    Cheap insurance to protect the headlight switch.
    Cheers,
    Oct 2008
    Burford, ON, Canada
    This reminds me of the incident I had in my 914 about 40 years ago. At the tail end of a 3 hour trip in the car on some of the major highways through Toronto ON, I finally needed to use my high beam lights. Upon flicking the switch I had smoke pouring out of the dash, so I pulled over and shut the car down. Panic over, I walked the final block home. Thank goodness that I was on a very quiet residential street, and could pull the manoeuvre without a hassle. I replaced the burned length of wire with a fused section.
    Jun 2018
    Sydney, Australia
    This is excellent advice, otherwise you end up with something like this... or worse...
    Mr car came like this and I had to rebuild the entire dash light loom...
    '95 993 | '70 911T
    Jun 2018
    Sydney, Australia
    John, most folks would at least ask before taking someone else's photo and using it on their commercial website, but...
    '95 993 | '70 911T
    Jun 2003
    Bend, Oregon
    Sorry, I've removed it. Bad etiquette on my part.
    Jun 2018
    Sydney, Australia
    John, it's fine. You have my permission to use it.
    '95 993 | '70 911T
