Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Testing a coil
  1. #11
    Dec 2011
    Monroe, WA
    I love the simple, yet extra important lessons I learn here.
    Thanks everyone that is willing to help us improve our (cars) and our lot in life!
    "Fahr drauf, bremsen ist feige!"
  2. #12
    Senior Member mathieulecomte's Avatar
    Dec 2016
    New Jersey
    Very interesting - I am guessing the specs may different if testing a 912/356 coil vs a 911?
  3. #13
    Jun 2018
    Sydney, Australia
    Quote Originally Posted by mathieulecomte View Post
    Don't know much about 912/356's sorry. However any ignition coil should have a similar configuration with a very low reading on the primary - around the 1 ohm mark or thereabouts, and a very high reading on the secondary - thousands of ohms.
    '95 993 | '70 911T
  4. #14
    912/356/pre CDI 911 coil operates like a traditional coil.
    Coils for CDI cars are, in fact, step up transformers.
    You can use a CDI coil on early cars in a pinch but an early coil should not be used on CDI cars.
  5. #15
    Dec 2009
    Copenhagen, Denmark
    Quick update. 911-hzk.de said the measurements I provided above on my coil are within spec.
    James Hurst #1638
    R Gruppe #514
  6. #16
    Jun 2018
    Sydney, Australia
    You said 165 on the secondary, did you mean 165K?
    '95 993 | '70 911T
