Results 1 to 7 of 7
Thread: 1972 paint code 324 ( metallic blue)
    Senior Member curtisaa's Avatar
    Pasadena, CA
    Does someone here have a good picture of this color ??? I've seen gemini blue , but my paint says 324.
    Thank you
    [FONT="Lucida Sans Unicode"]
    Curt Autenrieth
    S Registry # 152
    Porsches:
    1.6L 2.7L
    1.8L 3.0L
    2.0L 3.2L
    2.2L 3.4L h20 cooled
    2.4L 3.6L air & h20 cooled
    3.8L
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Hi Curt,
    I have a 72 in original paint Gemini.
    The Blue and Gemini are quite hard to distinguish unless side by side and the lighting plays tricks on both.
    This thread has pics of most of the colours and is a cool thread regardless.
    Go to post #47
    https://www.early911sregistry.org/fo...324+Blue+Paint
    Mark
    Aug 2011
    Eugene, OR
    This car belonged to a friend of mine. It has been repainted, but I was there when the final formula was selected. The paint shop tried formulas from all the usual suspects (Glasurit, Dupont, BASF, Sikkens, etc.) but none really matched the spot of undisturbed original that the shop saved just for this purpose. The paint you see here is Dupont custom matched by eye. I believe it is a good representation. Metallic Blue is a bit more vibrant and more "blue" than Gemini.
    - Arne
    324 is almost identical to 334 Metallic blue ... Here is Lars' '72 in Gemini and my '73 in (334) Metallic ...
    Hope this helps...
    Oct 2008
    Burford, ON, Canada
    2 digit sales code is the same, and the changeover seems to be late in the 1972 model year. Probably a minor formula change, maybe the silver flake. My data suggests it was Herberts manufactured.
    84 324 Blue Met to June 1972
    84 334 Blue Met from July 1972
    Thumbs up
    Thanks Dave...
    Never knew the probable change dates...
    I've seen the two formulas, and they are different, but pretty much to the same ends...
    Cheers
    Senior Member Peanut's Avatar
    Aug 2012
    Florida
    ...72 Targa by chance Curtis? ��
    Scott
    1968 911S
    1986 Carrera
    2006 Carrera S
