Results 1 to 10 of 10
Thread: Gas tank restoration
    Apr 2012
    Simi Valley Ca
    Any threads about gas tank restoration, or anyone in the LA or Ventura area doing this?
    Also, Wurth coatings are getting hard to come by in California. Anyone know what product I can use on a '69 tank to get the proper texture and dark grey color?
    Bob B
    Dec 2009
    Copenhagen, Denmark
    Any radiator shop will do this, I used San Leandro Radiator. I bought a couple cans of Würth undercoating which they appreciated.
    James Hurst #1638
    R Gruppe #514
    Apr 2012
    Simi Valley Ca
    James, Can you post a picture. How does the Wurth undercoat look? I notice that the original coating looked more like it was a rubber coating. I found L&M Strippers in Van Nuys that will strip it clean for about $200. When I talked to them on the phone, I told him I had an old gas tank with a rubber coating and wanted it all taken off and he said "Oh, a 911?"
    Local radiator shop told me he no longer had a hot tank. Seems that a lot of these shops we took for granted are fading away, too bad.
    Bob B
    Bob, I had a small radiator shop in Oxnard clean and coat the inside of my 69 tank, and then I finished the outside myself with Wurth products. It came out very respectable. Stripping the outside was an exercise in patience but a lot of home restoration is.
    1969 911 E #824
    Apr 2012
    Simi Valley Ca
    OK, got my tank back from L&M Strippers. Here are a few pics. Came out very nice! $225. 14232 Aetna Street, Van Nuys, Ca.
    He said he had stripped a few 911's for Singer, but they wanted him to do a LOT of cars, and he had to say no, because that would have locked out a lot of his regular customers. Bob B
    Senior Member rgupta250's Avatar
    Jul 2020
    Orange County, CA
    Similar Bob, did L&M do anything to the inside of the tank?
    1971 911T/ restoring to S-spec Coupe / Gold Metallic on Black
    1995 911 C2 / Guards Red on Cashmere Beige (Sold)
    Apr 2012
    Simi Valley Ca
    rgupta, nothing inside the tank. It was very clean inside, just a little discoloration right at the lowest spot. He just told me to finish the outside and put it in a trash bag. I will put some Kroil or similar inside before I seal it up.
    Bob B
    James,
    How many cans to coat the exterior of tank.
    TIA,
    Mark
    Nov 2003
    Santa Monica CA
    What is Kroil ?
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Senior Member jim amato's Avatar
    Feb 2011
    n.e. ohio
    a petroleum based penetrating oil
    registry #2072
