Thread: Searching the holy grale
    Junior Member
    May 2014
    Duesseldorf, GERMANY
    Hi guys,
    I am working on my 68s and I have the problem that my hazard flash relay is damaged. I would like to ask, if anyone can help with a used one. I don’t want to rebuild it with new components. Thank you.
    901 615 341 10
    Mit luftgekühltem Gruß aus Deutschland
    Thorsten
    __________________________________________
    Porsche 911 T Targa, Bj. 1973 1/2, US-Version, Farbe: 326 Gletscherblau
    Porsche 911 T Coupé, Bj. 1970, US-Version, Farbe: 1313 Bahia Rot
    Porsche 911 S Coupé, Bj. 1968, US-Version, Farbe: 6608 Agablau
    The turn signal flasher went bad on my 69 and I too couldn’t find an OEM looking replacement. I bought one of the solid state cube shaped ones. I took the guts out of the old one, cut a piece of PVC pipe to use as a spacer and stuffed the cube inside the old cylinder. Fit perfect and you can’t tell it’s not the original. Very easy to do.
    1969 911S
    1969 Datsun 2000...worth less, but more valuable
    Dec 2010
    Southold, NY
    I've done the same internal replacement several times on various relays. It actually is quite easy and undetectable. Save yourself much agita by testing your replacement relay to assure that it works with your wiring before installing it in the old canister.
    Jun 2003
    Bend, Oregon
    I love the way this community encourages good old fashioned New England ingenuity. Being from Vermont I think I may have a bit of that. I use it a lot on computers. I've discovered that there is almost always a way to get something done.
    Cheers,
