Results 1 to 5 of 5
Thread: Ignition issue RS clone, 2.7 CID
    Hello all,
    When it happened; cleaning up the chassis harness
    Decided not to start:crancks, fuel pump running, and fuel at the engine.
    Removed lead from the distributor cap, checked for spark again ground (engine case) , decided to spark, reinstalled, its started. Great. While running (20 seconds ish), I reached in to disconnect the gas pedal from the stem, when it released, I bumped the throttle forward, and the wires with my shoulder. Now it won’t start again.
    I need to trouble shoot the ignition system, see if I mistakenly cut/loosened a ground or power wire, or any wire that would effect the system.
    I looked at the coil, and it has 2 stud wire plug, and the coil is indicating “A” “B” i had my neighbor crank and i checked for voltage one by one, but no reading. Not sure if one is power and the other is ground.
    Thoughts
    Not really a question for the early S registry , there is no longer anything early S about your ignition .
    Fair enough. Problem solved. Incase another guy has a 2.7 CIS swap, The wire at the fuse was pushed in and the set screw was contacting the wire insulation and not powering up the high voltage exciter box/transformer/ignition controller, or what ever you want to call it.
    Maybe not be an early ignition, but still and early Porsche. Back to pelican.
    Senior Member 2.5MFI's Avatar
    Sep 2006
    Bend, Oregon
    Thanks for the trouble shooting info Rex. Good information for all. Glad you found the problem.
    Mark Jung
    MFI Werks
    Early 911S Registry #972
    Carrera T w/LWB, MT, RWS, PCCB
    72 T 66 x 100 MFI Twin Plug Coupe
    R Gruppe #686
    Apr 2011
    N.Calif., south of SF
    Glad you fixed your problem. Your posting of:
    Reminded me that a couple years ago I had a couple of seemingly weird electrical things ..... went through the screw-down connectors at the fuse box. Everything seems good after that. Probably not a bad idea with these 40+ years cars.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
