Results 1 to 10 of 10
Thread: What type of coil is this?
    I’m trying to identify which model year this ignition coil came off of.
    Quote Originally Posted by Rex1968s View Post
    Looks like a mid-year coil from your photo.
    What's the Bosch part number on the bottom of the coil?
    Here’s a pic
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Coil was produced September 1975
    Thanks! Looks like my coil is ok, i was able to ju,more power to the ignition box and its started. I need to find where it goes from the ignition key now.
    Nov 2010
    Darien, CT
    The 529 if I am seeing it correctly on the coil would be September 1975 manufacture date
    69 911S #1379
    65 356 SC #130757
    Correct for 74-77 mid-year cars.
    Mystery solved. When cleaning up the harness, I adjusted the 12V wire at the fuse and pushed the wire in a little too far, the set screw sat on the insulation, not providing 12V to the exciter box when the key is turned on. This took about 8-10 hours of ringing wires to realize I caused this issue 🤦*♂️🤦*♂️😂😩
    The biggest problems always seem to end up having the simplest solutions.
