Thread: Wiper Parking
    Dec 2013
    Connecticut/Florida
    Wiper Parking
    So I tested out my wipers on the rebuild of my 1971.
    I installed the arms so that the blades ran across the windscreen nicely - nice full sweep and staying on the screen. But, when I turned them off they parked in the middle of the screen.
    So I manually rotated the loose arms when the motor was parked so that they are where they should be parked on the drivers side. But of course, when I turn them on again they then go further towards the drivers side - and off the screen. So I can get them to park correctly but then they sweep only the drivers side before they go off the screen - Or, if I adjust the arms to do the full sweep they park in the middle.
    Thoughts ?
    1971 911S Coupe - Gemini Blue
    May 2006
    CT
    Simon
    The parking adjustment is made at the motor pivot. Check out this thread on Pelican.
    http://forums.pelicanparts.com/porsc...-too-high.html
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Dec 2013
    Connecticut/Florida
    Thanks Tom. I'll try that
