Results 1 to 7 of 7
Thread: Gas tank mounting questions and rust control in rocker boxes
    Apr 2012
    Simi Valley Ca
    Took my gas tank out of my '69S this weekend and found the front mounting hole in this condition. Doesn't seem that this hole should be raised like this. Does anyone have a pic of what it should look like? Or just tell me it should be flat to the surrounding area. I am including a few other pics of the front bulkhead. I think this car was hit slightly in the front at one time, but there doesn't seem to be much damage other than a few sloppy welds in each front corner.
    Also, there is a little bit of rust (this car has been in my garage for almost 50 years, so very little rust compared to some cars I have seen) in some areas. Do I treat this area with the POR products or something else. Also would like to put some product through some of the available holes (gas tank mounting holes, battery hold down holes) that will expand into the concealed areas around the tank, and also add something into the rocker boxes through some small drilled holes. This car shows no rust in the rocker box areas, but I would like to treat those concealed areas. I read about a product that will creep along the metal after applied, but can't remember it's name. Any help will be appreciated.
    Bob B
Size:  102.2 KBName:  IMG_1058.jpg
Size:  118.4 KBName:  IMG_1061.jpg
    Have you looked underneath the car where this raised section is to see if a misplaced jack did the damage? I say damage, because unless the 1969 tank mounting surround is different than the 70, 72, and 73 I've restored, it is not correct. Also, it would raise the tank at this high point and the seal between the tank and surface would not do its sealing job.
    Dec 2015
    NE Michigan
    Only pic I have of my 69. Im guessing flat.Name:  Screenshot_20211018-092740.jpg
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    yes the area should be flat..no big deal getting it back--the sloppy welds look factory to me..i do not see anything that would worry me to much..maybe the wiring could need a bit of refinement
    Apr 2011
    Central Florida
    Bob, with respect to the interior voids, they should be treated with cavity wax. The aerosol cans come with a long wand for hard to reach areas. Greasy Fingers on YouTube has a good video on the process.
    Regards,
    Dho
    dho
    Central Florida
    Member # 1968
    Senior Member rgupta250's Avatar
    Jul 2020
    Orange County, CA
    Bob, the product that Dho is referring to is made by 3M.
    https://www.3m.com/3M/en_US/collisio...vity-wax-plus/
    Best,
    Ravi
    1971 911T/2.45 engine spec Coupe / Gold Metallic on Black
    1995 911 C2 / Guards Red on Cashmere Beige (Sold)
    Apr 2012
    Simi Valley Ca
    Thanks for the replies. Cavity wax ordered.
    Bob B
