Thread: Heat Exchangers questions …1971
    Dec 2013
    Connecticut/Florida
    Just two questions….
    Installing the heat exchangers. It doesn’t look like the PET manual calls for any washers under the Nuts that attach the exchangers to the exhaust studs ?
    Just also wanted to also confirm that no sealant should be used ?
    1971 911S Coupe - Gemini Blue
    Mar 2016
    Italy
    Quote Originally Posted by Simonjjb View Post
    Yes, washers under nut aren't required, it's a really tight space so it better to have a good drag on the nuts. Also consider that thermal stress on washers can reduce tightening between surfaces leading the exhaust leaks. I suggest to only use 12 bolts.
    If I remember well PET report a mounting paste ... it's not a *must* but it should be a lube paste to be placed between screws and bolds to prevent stucking
    Oct 2010
    Southern Ca.
    No washers or sealant , but definitely anti-seize on the threads .
    Dec 2013
    Connecticut/Florida
    Thanks guys
