Thread: Any leads for M8 x 1.25 x 12 seat mounting hex bolts/screws?
    Aug 2021
    CO
    I will assume they were originally yellow zinc. These hold the sport seats to the tilting frames. 4 per seat. Thanks for any leads (other than what I have already found at the local hardware store)
    Cheers!
    Belmetric has these in the specs you’re looking for
    Apr 2012
    Simi Valley Ca
    Belmetric is an amazing site. Take some time and go through all the categories. It will blow you away. Just about anything you would need.
    If you want to make your own high pressure oil lines, you can buy the hose and fittings and then get your own Cohline crimping tool for only $1,690!
    Seriously, I have been working on VW and Porsche cars for almost 60 years and had a lot of German bolts: Kamax, Dera, Verbus, Ribe, FHS, etc. Sent a lot of Bolts, Nuts and Washers out to the plater until I figured it was cheaper to just buy new washers and Nuts. No brand name on them! So when I started working on my 911, I spent a couple hundred dollars to get a good assortment of grade #8 and #10 bolts and an assortment of washers.
    Some of the washers you take off your car have to be plated, because they are odd sizes (usually thick or weird diameter). Here are a few pics.
    Bob B
    900.075.023.02 DIN 933, M8x12, 8G gal Zn SS: N01023714 PCNA List: $0.63
    BelMetric BR8X12YLW - Hex Bolt 8.8 Yellow Zinc
    Apr 2012
    Simi Valley Ca
    $0.28 at Belmetric.
    Bob B
    Aug 2021
    CO
    Thanks all. I'm sure the sport seats in my 73 have been in and out of the car more times than I can imagine. The M8X12 bolts were tightened right up against the seat mount tabs. Should there be a washer? Just a standard flat or a split lock? I'd like to replace as close to factory as I can. Thank you.
