Results 1 to 7 of 7
Thread: CDI box testing
    Mar 2004
    Twin cities minnesota
    CDI box testing
    Hello all, What is the best way to test an early 3 pin CDI box not installed in the car? Thanks in advance.
    Sadly, the easiest way to test it is probably to install it in the car.
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    if you get one like that
    https://www.ebay.com/itm/294005266943?
    and a transistor like that https://www.infineon.com/dgdl/Infine...5aa335436b0fae you can build a bench test rig.
    I know there are also some that don't need the transistor/have it included, but I didn't find it in my quick search.
    Dec 2008
    Black Mountain, NC
    I would contact Bob Ashlock here on the board and talk to him, not sure what testing would cost but he is one of the best out there to recondition one when needed. My assumption is you are wanting a known good spare. they are small and easy to ship, he is in Orange County.
    Mar 2017
    Orange County, CA & Tucson, AZ
    Quote Originally Posted by Jerry L View Post
    +1 for Ashlock
    Bill
    Early 911S Registry Member #4087
    Instagram: @myflat6
    '72T hotrod 210 0228
    '82SC Targa
    '97C4S (sold - and regretting it)
    +1 for Bob A...the best!!
    Dec 2015
    Bordeaux, France
    If you have a 12V supply (like a car battery) and a coil, you can connect a coil and a spark plug to the coil with a wire running from the body of the spark plug to the negative terminal. The CDI sparks on opening the contact between the wire from the distributor and the ground. A first test would be to hear it whine when it is connected to 12V. From memory, the left terminal is for the breaker points, the middle one for +12V, and the right one goes to the + of the coil. The ground goes to the CDI chassis.
    Good luck,
    Dario
    ____o0o____
    1972 Targa 911S (one day), silver gray (maybe), member 3337
