Thread: Reinforced shock towers
    Hi folks,
    we are going to race with a 1965. The body has the reinforced/welded non adjustable front shock towers. I found some details here about it on this incredible forum.
    Problem is, we have to prove that this was done on behalf of the factory and not an aftermarket or private modification which will not be accepted by the rules.
    Is there a memo or any written statement from Porsche about this?
    Michael
    Michael Moenstermann
    Osnabrueck - Germany
    Early 911S member #1052
    'While accelerating the tears of emotion have to flow off horizontally to the ears.'
    'Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer'.
    'You can't treat a car like a human being - a car needs love'. (all Walter Röhrl)
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    If it isn't in the homologation forms https://historicdb.fia.com/ it's very difficult to convince the guys.
    In former times period Magazine Articles were accepted - nowadays not anymore.
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    if i remember correctly it is mentioned in one of the early bulletins.
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
    Perfect Haul, thats what I was looking for.
    Danke dir!
    Sep 2012
    Colorado
    For most of us gringos who don't race in Europe and don't understand the point of this thread, in Europe the 'rules' are taken much more seriously by the FIA than by any racing body in North America. In addition to the (fairly cursory) FIA "technical inspection" before each event, after each race all cars are sequestered in impound and inspected carefully against the 'rules', which are extraordinarily complex. Infractions wind up with a mark against the car being put onto the FIA HTP (similar to the logbook), and if not resolved before the next race (even in the same event weekend) the car is declared ineligible. It is quite a big deal. Not all FIA inspectors are equal, and it's interesting to hear them discussing/debating fine points with each other. So, 67Porsche911S needs to print out that bulletin and carry it with him to race events.
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
