Results 1 to 2 of 2
Thread: 66 Interior Door Glass Wiper "blade"
    There is a rigid wiper blade between the door top garnish and the interior door glass in the original design. As designed it clips on to the garnish. It is constructed similar to the rigid "U" channel in the window frame.
    I understand that it is NLA. What is being used as a substitute?
    Senior Member haul's Avatar
    Jul 2014
    bavaria
    https://www.early911sregistry.org/fo...or-on-door-cap
    the issue is solved over here - the 914 part will do the trick
    59 750 pre unit triton
    65 912 slate gray "erwin"
    73 914 ravennagreen "ferdl"
    erwin_loves_polo
