Results 1 to 10 of 12
Thread: PVC plastic sleeving around wire loom metal tags help .!
    hi guys im looking for some help with the PVC plastic sleeving around wire loom metal tags .
    i have a 69 car, can anyone tell me if the sleeving is 2 pieces or is it 1 piece with the back cut out and slipped over.
    I am looking for the stock / original method.
    if you have some photos it will be good for future reference.
    many thanks
    john
    Apr 2012
    Simi Valley Ca
    I think I know what u want. All of the sleving is a tube, no cut. I think some shrink fit tubing comes pretty close, and of course you wouldn't heat it to shrink it. The second picture shows u how to cut. Cut in at 45 degrees, then down the middle, then out at 45 degrees. Total length about 135 mm (5 1/4"). Inside diameter, about 8.75 mm (11/32"). Total length of cutout, about 38 mm (1.475"). Wall thickness, about .6 mm.
    The last pic shows how to mount it.
    It's one piece with the back cut out.
    Not sure about what exactly was used on your '69. I've purchase flexible plastic conduit from Wurth USA in the past, and it sure looks like the stuff Porsche used on other models and years. Available in a number of IDs.
    https://www.wurthusa.com/Electrical/...-0-5MM/p/07714
    Aug 2020
    SF Bay Area
    Pelican and Stoddard carry this tubing. Part number: 999-613-017-40
    - 1969 911T Ossi Blue #3981
    Jul 2006
    Corvallis, OR
    Kroon sells these.
    72S, 72T now ST
    Gentlemen thank you for all your replies as it was exactly what i was looking , bob thanks for the photos hopefully it will be a good reference for the future.
    regards jonny
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by catelluseng View Post
    this is what i use
    McMaster Carr carries black PVC tubing for doing just this in all sorts of different sizes I use it a lot when redoing wiring harness or making new ones for accessories, looks original and a lot less than any where else
    Thanks, Rick
    Apr 2012
    Simi Valley Ca
    moito,
    A tube with a 4 mm ID (Wurth 07714) will not fit on a metal tab that measures almost 10.25 mm across. You are going to need something with at least 7 mm ID. The reason I said above that the ID was 8.65 mm is because an 11/32 drill just fits inside the tube I took off my car to measure. I would buy at least an 8 mm ID tubing, maybe a little bigger.
    Bob B
