Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: PVC plastic sleeving around wire loom metal tags help .!
    I bought a long section of tubing from McMaster Carr…(by far the most economical)
    Matches very well
    I don’t have the spec at hand but you can measure the original old one.
    Will look tomorrow.
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Senior Member moito's Avatar
    AUSTRIA (tu felix)
    Quote Originally Posted by SIMI BOB View Post
    moito,
    A tube with a 4 mm ID (Wurth 07714) will not fit on a metal tab that measures almost 10.25 mm across. You are going to need something with at least 7 mm ID. The reason I said above that the ID was 8.65 mm is because an 11/32 drill just fits inside the tube I took off my car to measure. I would buy at least an 8 mm ID tubing, maybe a little bigger.
    Bob B
    sure ..i meant the type of product,with the correct diameter of course
