Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: ‘72 911T Mirror
    Nov 2021
    Austin
    ‘72 911T Mirror
    I'm new to 911's. My rear view mirror is partially discolored/stained. Is there a solution to clean this off or is only option is a replacement?
    DuckyName:  Mirror.jpg
    New mirror or have the glass replaced.
    Longhoods forever! silverc4s's Avatar
    Apr 2003
    Somewhere in Texas
    You sure it’s on the surface? Many old mirrors have the reflective backing attacked by moisture over time. No fix for that. If it is indeed on the surface, try medical alcohol for a start. If you can feel anything on the surface, try goof off as well. Happy PORSCHE ownership, and welcome to the forum!
    Bill Conway, Early S Registry member #254
    1970 S, 2.2L Silvermetallic Coupe
    1973 T, 3.2L Black Carrera Targa
    1969 T, 2.4L Silvermetallic Targa
    Nov 2021
    Austin
    Quote Originally Posted by silverc4s View Post
    I don't think it's on the surface since it's smooth like the clean side. I think you're right about the reflective backing being damaged by moisture. It's the original mirror. Is it possible to replace the glass insert without damaging the plastic housing?
    Ducky
    Apr 2003
    Somewhere in Texas
    Quote Originally Posted by duckytran View Post
    Ducky
    Not really if you want a good result hunt down another mirror. There are a few guys in Austin that can help, I’m sure..
    Nov 2021
    Austin
    I found a replacement mirror on the Pelican Parts Forum. I was hoping for a cheaper solution. I suppose nothing is really "cheap" when it comes to Longhood 911's.
    Ducky
    Apr 2003
    Somewhere in Texas
    Ducky
    Well, you could always hunt down an old Lamborghini to fix up. That might be a cure.
    Seriously though, my favorite part of fixing old Porsches is they stay fixed one it’s done right. (Unlike some marques we all know)
    Nov 2021
    Austin
    Point well taken. Thanks!
    Apr 2003
    Somewhere in Texas
    No offense meant, I assure you. Again welcome to air cooled longhood ownership. Enjoy the ride!
    Nov 2021
    Austin
    None taken!
