Results 1 to 7 of 7
Thread: Rear brake line
    Rear brake line
    Guys
    Anyone have a used rear brake line….the one from the union to DS , over the torsion tube
    PMB is having issue w/ bender , keeps using the superceded part # which goes under the tube.
    Hope to send them an original
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Sep 2020
    Altoona, PA
    I think this is the one you are looking for. LMK
    Dan
    ESR member 4002
    1971 911T project
    1999 Boxster
    2001 Porsche 996 Cabriolet 4
    Sep 2020
    Altoona, PA
    The new URO line needs a little tweaking, but it’s pretty close.
    ESR member 4002
    1971 911T project
    1999 Boxster
    That’s the line….
    Did you buy URO as set ?
    Crazy, but if you would send Old to PMB , I’ll pay
    Let me know if possible
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Sep 2020
    Altoona, PA
    Yes, I bought the complete URO set.
    I'll tweak it to line up with the frame tab for the rubber hose. No sense in reproducing something wrong.
    PM me their address and I'll get it boxed up.
    Dan
    ESR member 4002
    1971 911T project
    1999 Boxster
    Thanks Dan
    Will get out to you tomorrow
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Guys
    Sorry but its been a couple of years….
    I got side tracked with the rest of the restoration ..
    I do still, need a used brake line to send to PMB or….
    Can someone make one to match the original (only 70-71 )
    Must be the one over not the superseded version
    Thamks
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
