Thread: Can you get a differential out of 911 without removing heat exchanger or engine??
    May 2014
    South East USA
    Tonight I started to remove my normal differential, for replacement.
    I can see that it looks tight to pull it out with the heat exchanger in the way.
    Can it be removed without moving the heat exchanger?
    I have done it in a 912...wasn't so hard.
    This car: 911T 1971 2.2
    May 2014
    South East USA
    As I got further along, it's starting to look like it will come out no problem.
    It's not out yet. Enough for tonight. Tomorrow, I'll take off the right half shaft.
    Dec 2013
    Connecticut/Florida
    Hey scott...
    Can you send me a photo of your throttle bell crank angle/setting ? Like a picture just to the left of the one above - or maybe its too late?
    1971 911S Coupe - Gemini Blue
