Page 8 of 9 FirstFirst ... 6789 LastLast
Results 71 to 80 of 85
Thread: Pet Peeve - Improper use of Euro front signal lenses
  1. #71
    Dec 2013
    Connecticut/Florida
    [QUOTE=jaudette3;1112861]Yeah, you're right. Here are a couple pictures of a customer's car that is shown at the Petersen from time to time:
    Attachment 564543
    Attachment 564544
    Signal Yellow or Orange?
    1971 911S Coupe - Gemini Blue
  2. #72
    Jun 2003
    Bend, Oregon
    Some pictures of an original:
    To complicate things further, there was an later (edited, thanks Michael) generation that had a non-reflective plastic piece attached and apparently no bent over flange on top:
    I think the flange shows more in the picture of the car because the reproduction lens has a straight line between the amber and clear portions rather than the correct curved line seen on the lens in the picture above.
  3. #73
    Jun 2003
    Bend, Oregon
    [QUOTE=Simonjjb;1135113]
    Quote Originally Posted by jaudette3 View Post
    Attachment 564543
    Attachment 564544
    Bahama Yellow.
  4. #74
    Nov 2003
    Santa Monica CA
    the original light box shows the flair going toward the center of the box. the example you show of the silver car shows the flair going toward the end of the box by the screw hold down for the box. Did somebody put these in backwards?
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
  5. #75
    Jun 2003
    Bend, Oregon
    If they're backwards, and it looks like it, that means yours truly built them that way. Which is really stupid but by no means impossible.
    Update: Relieved to report that they were not configured incorrectly. See photos below.
    Thanks,
  6. #76
    Nov 2003
    Santa Monica CA
    Can they just be switched or will the bulb be on the wrong side
  7. #77
    Nov 2003
    Santa Monica CA
    Also maybe I can just bend the flair the other way or if worse comes to worse cut the flair off with tin sips .
  8. #78
    Nov 2003
    Santa Monica CA
    And the picture of Dave Awesome's divider shows no flair
  9. #79
    Jul 2003
    Santa Cruz, CA
    Quote Originally Posted by raspy2point2 View Post
    Thats a SWB bucket and I wouldn't use it as a comparison to the LWB buckets. The flair should always sweep from front to back of the light bucket. The little plastic reflector is not an Earlier version, it was a Later version.
    Michael
    -Dusty 70S Coupe
    -S Registry #586
  10. #80
    Jun 2003
    Bend, Oregon
    Good Way to Start the Day
    The owner who sent me the picture that I posted here just sent me some with the lenses removed. Thankfully the U.S./Euro converters are configured properly. It appears that my initial conclusion regarding the dividing line of the lens was correct. Big relief to me, I lost sleep over this last night.
    Name:  thank God 2.jpg
    Thanks,
