Results 1 to 7 of 7
Thread: replacement key from vin #?
    PCaricous Fanaticous G50911's Avatar
    Jul 2014
    SF Bay Area
    hi all. just started my restoration on a 67 911. i can’t seem to find my keys tho. has anyone had any luck getting a new set made by providing a vin # and proof of ownership? are there any other alternatives like having a skilled locksmith come out and decode the tumbler?
    1967 911 - #308439
    1971 911 - 3.6 hotrod aka Vader
    1989 911 - Carrera Cabriolet
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    I have had new keys made by providing the key number and years ago it was fairly easy to get that from Porsche. I am not sure how hard that is now. However if the car still has the original locks the key number is recorded on the kardex and you can get it that way.
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Senior Member NZVW's Avatar
    Feb 2017
    Auckland NZ
    Quote Originally Posted by G50911 View Post
    hi all. just started my restoration on a 67 911. i can’t seem to find my keys tho. ?
    Do you need them ?
    Mark
    Jul 2014
    SF Bay Area
    thanks hugh. do you know if there’s a source to get a kardex for my car? i seem to recall kardex’s are nla. i did get a coa when they were still available. if not, did you contact porsche na to get key numbers?
    1967 911 - #308439
    May 2014
    South East USA
    several times, with lost keys, most from friends...i have removed the chrome door handle. inside the door handle is a lock tumbler, (a cylinder with sliding metal wafers)
    You can slide in a blank key....see where to file the teeth.
    One by one...you just file....(i use a dremel, diamond disc). you can see the wafer lower until it is flush. For me, it is very fun.
    With your key it is probably about 6 wafers. your key is easy, at is only one sided.
    That's the route I take without going to dealers, finding numbers, paying others to make it work.
    It usually takes 20 minutes. (maybe a little longer to remove the handle itself)
    Another thing i do is take a photo of the key...that way i have a record, and it gives me a head start as what the shape will be.
    You can most likely mail your lock cylinder to a guy too. (but i prefer to do it at home)
    Oct 2008
    Burford, ON, Canada
    Yes, I can get your Kardex with the Key codes. Please email me.
    Aug 2017
    el sobrante ca.
    i gave Sierra Madre my kardex code and they made me a key.
    it was inexpensive, quick and worked fine....
