Greetings,
is it possible to get/know a VIN from a secret/under the dash number ?
Got the case with a chassis with a clear(ed) VIN in the front trunk but has a secret number stamped.
Cheers
Xavier
Greetings,
Cheers
Xavier
O-G 26 - Early911S 2407
I beleive it is possible, depending on the year, early cars the dash stamp matched the vin and in later years
it was a production number. DaveP would be a good member to contact.
911 1967S 308470
[B]911 1965 302962 Polo Red
911 1965 300760 White SOLD
911 1971S S/T 2.5
914-6 1970 GT 2.3
Early S Reg #2699
porsche does not give this info away.
unless....
somebody forges a vin and forgets to alter/remove the production#.later sells this car to someone who then finds out something is fishy .if this someone goes to court and if his lawyer pulls the right levers porsche will tell you the vin to the production#
As mentioned, Porsche will not give you a production (dash) or chassis number if you only have one of the numbers. However, about 5 years ago I gave both numbers on a car and they verified that they were a match to their records. The COA process has since changed and become more restrictive on information and costly so I'm not sure now, but it is a reasonable argument that confirming or denying such a match helps suppress fraud, which is the primary reason they are currently so restrictive on numbers.
Not trying to fraud here, got an opportunity to buy a complete 2.2 1971, and am enquiring to see if it is a scam/fraud or not.
Title has a VIN, and chassis not. So if I could get the secret number matching a VIN, I could check if the VIN on the title matches the secret hence could stand the correct VIN again. If not, then I will not buy it.
Thanks for the inputs.
Xavier, it is anyway possible to check whether the secret number corresponds with the car type, if not to the exact vin ...
- 1973 Biancaneve - 911 2.4 S/F Ivory
- 1977 Fiona - 911 Carrera 3.0 Oak Green Metallic
- 1993 Bellatrix - 964 Turbo 3.6 Black
