Results 1 to 8 of 8
Thread: 61mm factory LSD Flanges
    I have a pair of coarse spline transmission flanges for use with the factory ZF LSD used from 1969-71
    These are 61mm long on the shaft section rather than 56mm of the std flanges. I believe these are very difficult to find.
    $1000
    Quote Originally Posted by knapmann View Post
    ...for use with the factory ZF LSD used from 1969-77?
    These are for 1969-71, and not 1972 or later.
    Jon B.
    Vista, CA
    Quote Originally Posted by Jon B View Post
    Jon B.
    Vista, CA
    Thanks for the info, maybe you can school me further as I can find very little info on these? I thought that the same diff was used from the 901/13 in late '69 through to when the 915 went to 8:31 R&P in the mid 70s? if my thinking is wrong, what is the difference between the 69-71 flanges and the 72+ flanges.
    ...what is the difference between the 69-71 flanges and the 72+ flanges.
    The width of the axle CV joints changed in '72, and a corresponding change was made to the flanges.
    Flanges from '72-on have 915 numbers, then 923 numbers from '76 until the fine-splined versions.
    Jon B.
    Vista, CA
    Jon B.
    Vista, CA
    Great info, thankyou!
