Porsche Carrera front fender oil cooler sold with or without OEM fan with adjustable temp controller. Everything you need to mount the cooler and wire controller including relay. The input ports have been repaired (blue fittings) and the entire unit has been pressure tested to be good. The cooler with mounting hardware can be purchased separately or the controller alone with the fan can be purchased alone. Pricing is on the pictures but the $780 should be $730. Shipping is $50 for the entire setup and $35 for the cooler + with hardware alone $35. The controller ships for $15 alone. The controller uses a probe in the radiator-other options are available. I take Paypal at pkg911porsche@aol.com with no charge for family and friends and add 3% for merchandise. Questions-call Peter at 952 835-9969 or email me at pgeorge911@aol.com. Thanks for looking and hope to hear from you soon. Peter
[img]http://forums.pelicanparts.com/uploads26/P10508681632592499.jpg[/img
