Thread: Wiring path for SWB fresh air blower fan (Webasto)
    Die schönste Rennstrecke der Welt. Nordschleife's Avatar
    Dec 2006
    I'm installing a fresh air fan blower in my 1968 SWB. Can anyone please tell me how the wiring harness is routed down into the smuggler's box from the switch & relay? Photos would be wonderful if not too much of a hassle.
    Is there a hole that the Webasto blower wiring harness passes through?
    Or does the harness take a different path, such as tucking under the steering column plastic cover instead?
    Thank you!
    Best,
    Andy in New Hampshire
    Early 911S Registry #1246
    1968 Porsche 911 Cotswold Blue/Schwartz #118 35153
    1962 Marcos G.T. 1000 Gullwing historic race car - now sold and racing in FIA events in Sweden
    "Pro Patria Vigilans"
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    I'm not sure if these will help. I didn't documents well some areas of my restoration. This was from a '68 Normal Sportomatic
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
    Dec 2006
    That definitely helped! Thank you, John.
    Is there a way to make the switch knob light up when pulled? I have a 1968 and the switch does have a 12v bulb and the glass/plastic tube inside (switch 901.613.625.31). There is a yellow jumper cable on the back of my switch to the bulb but I'm not sure where to connect it. I wired the switch according to this VERY helpful earlier post:
    https://forums.pelicanparts.com/uplo...1377006644.jpg
    But I don't see the jumper for the 12v light bulb in this diagram, am I missing it?
