Results 1 to 8 of 8
Thread: Throttle body rebuild shops
    My 69 may be needing my throttle bodies rebuilt, or, turned in as cores for a refurbished set. I've heard from Gus Pfister that Eurometrix is the place to go. They are real backed up, and I guess changing locations, this may take some time. Does anyone have suggestions for shops that specialize in this? Thanks
    Apr 2011
    N.Calif., south of SF
    Aaron Burnham of Burnham Performance, Camarillo, CA. Did excellent work, knowledgable and you will appreciate his work and results.
    For an example, he asked if I wanted to replace the aluminum linkage with steel version. Had no idea there were 2 versions.
    Here's an Excellence Article https://www.excellence-mag.com/issue...ticles/mr-t-me
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Aaron has moved to Berkeley and has a full time job that is not Porsche oriented. I do not think he is available to service these, at least not at this time.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Apr 2011
    Thanks Paul, had not heard that.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
    Matt Blast @ Eurometrics in Massachusetts...well regarded and highly talented...did several sets for me a few years back.
    Aug 2010
    Colorado
    From what I can gather calling around for 3 or 4 hours today Eurometrics might be the last shop to do this kind of work. They are busy and about to shut down and move to a new location. So if you want the work done it might be worth getting on their list.
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    Feb 2020
    NW CT
    +3 on Matt. Great guy, and great work. He just did my RS TBs/stacks. I think it took ~6 months and they were in nice shape when he started, but are phenomenal now. Any appetite to use webers in the interim while you wait? While every cost is nuts, the incremental cost assuming you sell them in a year or two will probably be relatively small compared to having TBs rebuilt by Eurometrix and the whole MFI system working properly (presumably Gus is doing your pump).
    MBR #3926
    '71 911 T Targa "Rick White"
    '71 911 E "Karen"
    '70 S/T
    '16 CD
    '10 E61 "Vomit Comet"
    Thumbs up
    Matt did my TB's and linkage in '03 .... Came back looking like jewelry.....
    Well over 100,000 miles since... still on the money and run'n smooth and strong...
