Results 1 to 9 of 9
Thread: Blower fan hoses & final wiring
    Die schönste Rennstrecke der Welt. Nordschleife's Avatar
    Dec 2006
    I am installing the fresh air duct hoses. Where exactly is the “Y-shaped” metal tube connector installed on the passenger side under the dashboard? Could someone please send me a photo of a factory-installed Y-tube and hoses located up under the dashboard on the passenger side? I want to cut the existing hose in exactly the correct place when I install the black metal Y-tube.
    I am also completing the installation of the Webasto blower wiring harness now. The last 2 connectors remaining are for the two red wires at the end of the wiring harness. One red wire goes to Terminal 75 (or terminal 54) on the ignition switch, correct? But the final longest red wire is a mystery to me… does it connect to fuse #3 at the fuse box?
    Best,
    Andy in New Hampshire
    Early 911S Registry #1246
    1968 Porsche 911 Cotswold Blue/Schwartz #118 35153
    1962 Marcos G.T. 1000 Gullwing historic race car - now sold and racing in FIA events in Sweden
    "Pro Patria Vigilans"
    Senior Member JT912's Avatar
    Jan 2008
    Eugene, OR
    This is the only image (terrible) I have and I don't remember if it is in the correct orientation (drivers side or upside down for the passenger side).
    John Thompson
    1966 912. My first car. Bought it Nov. 25, 1988. Still have it.
    Dec 2006
    Thanks, John! I’m not sure where that oval opening is in your photo?
    I was imagining the “Y-tube” would be pointed the opposite of your photo; two openings pointed downward & the other single opening upwards. Air pushed out from the fresh air blower in the smuggler’s box would travel through the firewall hole/hose to join the warm air rising up in the paper/aluminum vertical 50mm hoses from the sills at this “Y” junction. The “joined” air then continues up to the defroster vents by the windshield.
    That would mean the Y-tube must be located in the passenger compartment up under the dash and directly adjacent to the glovebox (tucked up into the top right corner of the passenger footwell). Is that where it is?
    Jan 2008
    Eugene, OR
    I sold this car many moons ago so much of what my pictures show I am using my aging-memory to put them in their place. I think this oval hole is located on the foot wells under the dash. It would be covered with the carpet and the carpetted storage pocket. I have this other image which I now think is the driver's side. I think this is the antenna lead. The first picture I posted must be the passenger side. It was horizontal in my file and I rotated it. I'm not sure I rotate it correctly
    John Thompson
    Jan 2008
    Eugene, OR
    I think this is the correct orientation.
    John Thompson
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    Quote Originally Posted by Nordschleife View Post
    the oval thingie is the reinforcement panel that targas have and coupes not..here`s the area of a coupe with webasto gas heater pretty sure the Y-tube is installed the same way as on "blower" cars
    Jan 2008
    Eugene, OR
    Yes. It was a soft window Targa Sportomatic.
    John Thompson
    Dec 2006
    Perfect! Moito, thank you so much for clarifying and for sending that photo. Exactly what I needed to see!
    John, my thanks to you too!
    Now I can finish the blower installation IF I can figure out where to connect that last red wire to the fuse box.
    May 2013
    AUSTRIA (tu felix)
    if i remember correctly... for your 75 there should be is a single unused wire with a yellow or black connector sleeve.it exits the main harness in the gauge area...it is the same one that gas heater cars use.......could be all wrong
