Results 1 to 10 of 13
Thread: 901 transaxle gear oil
    My box has 100k miles and although the synchros are OK it would be nice to get as much life out of them as possible.
    I have heard good things about Redline MT-90 gearbox oil.
    Any comments regarding this lube or alternates?
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    Redline shock proof heavy in my race cars and street cars. Seems to protect even the pinion gear.
    Quote Originally Posted by sanders View Post
    Pinion from a 944-series transmission in the shop right now, was run with Redline Shockproof according to the customer. ymmv.
    Name:  22-01-29 002 sm.jpg
    I asked a venerable gearbox/engine builder who posts on this site and he said he uses 75W90 conventional oil, not synthetic.
    Paul Abbott
    Early S Member #18
    530.520.5816
    Because Porsche synchros need friction to work properly.
    I was also told by a Porsche gear box expert to only run conventional Dino oil, as you mentioned 75/90
    1969 911 E #824
    Lightbulb
    About 30 years ago I found that the last three posts were very true...first hand
    I had a crunchy 915 box and read somewhere that a full synthetic would fix it ....
    Went to a motorcycle shop and got some VERY expensive synthetic gear oil (Redline I think)
    Old out, new in, and could hardly shift the car at all ....
    In went dino again ... and the 915 was eventually rebuilt...
    ... and so it goes
    I got 145,000Mi out of my box running Swepco 201, so I guess it's a good oil.
    Senior Member TheBrownCar's Avatar
    Jan 2021
    Orange County, CA
    Hey Paul,
    We also use Swepco 201 here at the shop and have had great success for many years. We love it. Hope you are enjoying having your car back!
    Clay
    Clay Carr
    R Gruppe #806
    1973 911T Hot Rod
    Kendall is fine as well.
    Tom
    PS: I think if you go over to Pelican you can find endless debates (if you're bored).
    Early S Registry #235
    rgruppe #111
