Thread: '68 Targa Frame identification help needed
    Oct 2004
    Cambridge, MA
    Pics attached of two vertical bars for a '68 and a '73 Targa vent windows. The vertical channel on the left has a steel bar with two threaded holes that has been riveted in and no hole for the screw that attaches the "nike" that the vent window goes into. The one on the right is from a '73 and that is the design I was expecting when going to put the window frame together. The '68 set came to me with nikes that have the threaded tab and the bracket I was expecting to rivet back in with the spacers.
    Is the bar on the left correct for '68? If not, what is it correct for?
    Tru6 Restoration & Design
    69S Targa, Velvet Green
    73T Coupe, Gemini Blue
    Early S Registry #1462
    Oct 2005
    wash dc/ los angeles ca
    Maybe for a coupe vent that is not movable ? Just a WAG Shaun ...Bert
    Oct 2004
    Cambridge, MA
    Thank you Bert, I just checked a fixed set here and that's it exactly. What a tragedy. Pulley is exactly what I needed, thank you!
