Results 1 to 2 of 2
Thread: Is there a 935 spring plate how to thread out there
    Aug 2010
    Colorado
    I've googled, been here, Pelican, 912BBS, Rennlist. I can't find any thread on setting up and adjusting 935 type spring plates. Anyone have info you can post?
    Chris
    1970 Irish Green 914-6 w/2.2S
    www.reSeeWorks.com
    The only advice I’ve followed was to keep the spring plate and the trailing arm pick up point in the in the same plane as originally designed. Raise the spring plate pick up 1”, raise the trailing arm pick up 1”. The rest is just ride height and alignment.
