Results 1 to 2 of 2
Thread: RSR 2.1 info
    RSR 2.1 info
    I've been on a bit of a research binge as of late, stuck on the '74 RSR 2.1 or "Baby Turbo"....thought someone on here might have some cool info in the vane of; induction bits, case halves used, suspension etc. Hard to find solid specs or even pictures from that program other than the usual pictures that have been passed around. I know its not an "early" car, but thought there might be some good tidbits floating out in the earlyS ether. Thanks chaps!
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    you could listen to the german Podcast alte schule
    The Singer, Kussmaul, Barth interviews. IIRC they told a bit about the cars genesis.
