Results 1 to 10 of 12
Thread: Fasten seat belt buzzer
    Senior Member dirk07's Avatar
    Apr 2016
    Stuttgart, Germany
    fixed the wiring of my fasten seat belt warning system and the light work like it should.
    Unfortunately the buzzer not.
    The car is an early 8/72 MY73. Had the audio warning/buzzer also been in MY72 cars or is it MY73 only?
    My MY72 has a working light only. I've never known it to buzz.
    Apr 2016
    Stuttgart, Germany
    Checked my manuals and the 12/71 911T US manual mentions a buzzer.
    Where is it located?
    to the right of the glovebox, sort of in the corner above the kneeguard
    Veryirritating, as soon as I found it I pulled it out
    Senior Member 911kiwi's Avatar
    Feb 2003
    Auckland, New Zealand. And Los Angeles, USA.
    Agreed David, I did the same!
    Kiwi
    1972 911S
    1967 912
    1959 356A Conv D
    Early S Registry # 306
    Apr 2016
    Stuttgart, Germany
    Found the relay above the AC vents
    How does the buzzer look like?
    Remove it, that is the buzzer.
    Buzzer
    Here is some more info
    Dave Reu
    Member #3949
    1973 Silver Metallic 911S
    Apr 2016
    Stuttgart, Germany
    Thanks Dave and Ed.
    Problem solved. One of the pre owners put there a normal Wehrle relay. Wondered how this normal relay should buzz at all.
    So I ll need the real 91161511700 relay.
