Results 1 to 10 of 10
Thread: Chevrolet cars
    Junior Member
    Dec 2021
    Chevrolet cars
    Types of Self-leveling Laser Levels: Pros and Cons of Each
    There are three main types of self-leveling laser levels depending on their technology of operation. These self-leveling laser level types are; Wire-suspended compensators, Pendulum or Gimbal type laser levels, and electronic self-leveling types. It is important to pay attention to these technology or mechanism types when searching for the best self leveling laser level and fortunately, you can rely on the best self leveling laser level reviews at LaserLevelHub to make the best choices. The pros and cons of each type of self-leveling laser level are highlighted below;
    Wire suspended compensator self-leveling laser levels
    This is one of the oldest types of self-leveling laser levels that rely on pendulum plumb bob and this technology is found in the auto-leveling optical levels today. The main principle behind this technology is that light is projected into the compensator, before entering the prisms of mirrors before it finally exits the lenses and other prisms.
    Pros
    -Simple and very accurate
    -Cheaper.
    Cons
    -It can be easily damaged due to the platform hanging on thin wires.
    -It requires more checks and calibration.
    The Pendulum or Gimbal Type Technology
    You must have come across this type of self-leveling technology when reading the best laser level for builder reviews because it is quite common among dot and line lasers. The mechanism comes with a knocking knob for protection. The principle of working is similar to the wire suspended in that a central pendulum is mounted on a gimbal bearing, hence the pendulum will float freely to self-level your projects.
    A magnetic stop is normally included in the mechanism to stop the movement of the pendulum when the level is not in use. You can read more on levels with pendulum technology in the review of the best laser level for builders at LaserLevelHub Best Construction Tools Evaluated and find a great bargain.
    Pros
    -In-expensive and highly reliable.
    -It offers a more robust mechanism for fast self-leveling.
    Cons
    -It only relies on a friction-free bearing to work; hence its functions may be impaired by wear and dust.
    Electronic self-leveling
    This is the most advanced type of self-leveling technology around and it is mostly found in rotary self-leveling levels. It is quite similar to the pendulum technology level except that it doesn’t float. The pendulum found here comes with a mounted electronic sensor to ensure that the pendulum moves only in the direction dictated by the sensor. The electronic sensors are vials and they normally come with a light detector on each side of the vial.
    When the adjoining bubble in the device is central, a maximum amount of light is allowed to pass through. This type of self-leveling laser could be the best laser level for electricians or builders or construction workers.
    Pros
    -It is more accurate than other options
    -It is programmable to accommodate more features.
    Cons
    -It can be a little slower than the other two options due to the mechanical and electronic components working together.
    You can read more on electronic self-leveling levels at ⫸⫸⫸Best Construction and Power Tool LaserLevelHub.net✵✵✵ to ensure that you get the best bargain for your investment.
    Thumbs up
    Interesting first post...
    Sure.... My '67 Malibu has been sharing the garage with the 911 for almost 30 years ....
    Aug 2021
    CO
    I have a 76 K5 survivor. Just over 100K original miles. Not perfect, but every place/show I take it, people are all over it with smiles. Real fun rig.
    Aug 2021
    CO
    This! Love it. Well done holding on to it....
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Quote Originally Posted by SantosFord View Post
    Hello everyone! Are there any fans of Chevrolet here? Which model do you like best? I will be happy to create a dedicated topic to talk more about it, hoping it will interest some of you.
    To me this sounds like a bot.
    Senior Member BrentF's Avatar
    Sep 2012
    Toronto
    Brent
    '70 911S
    '68 TR250
    Sep 2012
    Toronto
    This was the Corvair's stable mate: '66 427/425 Corvette
    Brent
    '70 911S
    '68 TR250
    Thumbs up
    VERY cool Brent ...
    I had a chance to drive a '67 390/427 Vette back in '67 when I was 18 ... A whole lot of car on VERY skinny tires ...
    Senior Member moito's Avatar
    May 2013
    AUSTRIA (tu felix)
    not sure which chevy i like best ....but this is the worst
    Member kent olsen's Avatar
    Sep 2010
    McMinnville, Ore
    /Users/Owner/Desktop/albums/DSCN7710 2.jpg
    A classic Mini Cooper and a 65 Vett (it's called the Hemi/Vett because of the engine), share my garage with my 72 Porsche 911.
    Kent Olsen
    McMinnville, OR
    72 911 upgraded 3.0L
    RGRUPPE # 104
