Results 1 to 2 of 2
Thread: Recaro Tilting Seat Bases (Reproduction) Pair
    FS: Recaro Tilting Sport Seat Bases Brackets with sliders (Reproduction) Pair
    A pair of reproduction Recaro tilting Sport Seat Brackets Bases with sliders, Left and Right. Very much like new.
    For Sport Seats 911/912 69-73 Years
    These are really nice reproductions and they slide better than originals. The release mechanism is a "double locker" but it's mechanism is different and the release lever is not on the side but basically between your legs as a bar. Otherwise, they are exactly the same.
    Has genuine Recaro knobs.
    Seat belt attachment points are slightly different and you will need to use a longer bolt, it is the same thread pitch. Otherwise in the exact same location as originals.
    I will supply the four necessary seat belt bolts and spacers. They are Recaro bolts specific to seat belt attachment.
    They bolt up to the car frame exactly the same. The seats mount exactly the same.
    They are powder coated from the manufacturer. The right one has small area where the powder coating was damaged. About 1/2" x 1/4" on the tilting release lever. It has been painted and is not visible unless the seat is tilted fully forward. It can be seen in the one photo.
    They weight slightly less the originals.
    Without really looking / knowledgeable, one would not be aware they are not OEM.
    Available from Stoddard and some aftermarket seat manufacturers.
    These came with a pair of Italian reproduction Sport seats.
    $1150 for the pair plus shipping. I'm estimating the box would be about 30 pounds and shipped from NC
    Price Reduction to $1150 for the pair
