Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 80
Thread: My 914 lightweight project
  1. #41
    Feb 2021
    Stuttgart-Germany
    the work on the driver's side!
    After a bit of Paint/gravel protection removal, it wasn't looking promising:
    And not much better without the jack point triangle :
    So I prepared the floor pan:
    And made some cut:
    Now I could see the damages better:
    So I made a template :
    And the part, from cutting to adjusting to welded:
    Then some repair on the inner firewall:
    And the pan:
    And its reinforcement:
  2. #42
    Feb 2021
    Stuttgart-Germany
    And the triangle, no chance to repair the old one so I made a new one:
    And that is one side done:
    Stay tuned
    Antoine
  3. #43
    Feb 2021
    Stuttgart-Germany
    quote="TRS63"]So, next I fixed the clutch tube.
    First the part on the firewall, I don't know what a PO was thinking with this thick piece?!
    So I removed it and found a damaged firewall:
    So removing what is damaged:
    Making the patch:
    Adjusting:
    Welded:
    And the front fixation, cut the access :
    The issue:
    Welded (pic was ongoing, I welded the whole length but forgot to take a picture):
    And closed:
    Stay tuned
    Antoine
  4. #44
    Feb 2021
    Stuttgart-Germany
    So, I then worked on my engine side panel:
    Adjusting:
    Then the necessary holes:
    Then the sealing guide:
    A before-after:
    And in place :
    Bests
    Antoine
  5. #45
    Feb 2021
    Stuttgart-Germany
    I think the next step was quite logical..the battery tray
    I did built it by hand couple months ago:
    So it was time to adjust and weld it, first the bottom part:
    And then the top:
    All done and all fits great:
    I then found one last hole on the firewall:
    That I welded close:
    And now we have a nice engine bay/right long:
    Starting to look good!
    Antoine
  6. #46
    Feb 2021
    Stuttgart-Germany
    I have more to share with you
    This corner was ugly:
    So I decided to take care of it:
    And welded:
    And the outside part, before:
    Starting with the bottom part:
    Welded:
    And the top part:
    And here we are:
    Bests
    Antoine
  7. #47
    Senior Member Gumby's Avatar
    Jul 2006
    Pine Bush NY
    WoW....great work and diligence
    Ron
    1973.5 911T
    1974 BMW R90/6
    1986 Carrera, Plan "B"
    1987 BMW K100RS Motorsport
    2004 BMW X3 6 speed manual transmisson
  8. #48
    Senior Member Fubawu's Avatar
    May 2013
    such a satisfying thread!
    911 1967S 308470
    [B]911 1965 302962 Polo Red
    911 1965 300760 White SOLD
    911 1971S S/T 2.5
    914-6 1970 GT 2.3
    Early S Reg #2699
  9. #49
    Feb 2021
    Stuttgart-Germany
    Thanks so much guys for the support!
    Next step was the bottom of the B-post..here you go :
    Empty space:
    Home made part being adjusted:
    And welded:
    Bests
    Antoine
  10. #50
    Feb 2021
    Stuttgart-Germany
    So, then comes a big step..the quarter panel!!
    I made it myself of course..first, adjustment:
    And then cut, tack welded:
    And then welded:
    My door gap is so much better than it was!
    Planishing:
    And done:
    The last missing part was the small bracket at the front of the wheel:
    All looking good:
    Thanks for following along,
    Antoine
