Results 1 to 7 of 7
Thread: What line is this ?
    What line is this ?
    What is the small line thru grommet below the pair of brake lines and just above the hole for the master cylinder ?
    Thank
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    May 2014
    South East USA
    It must go to the switch thing on the master cylinder.
    Senior Member 9er's Avatar
    Apr 2010
    Adelaide Australia
    Or it is the master cylinder overflow.
    Its possible but it comes front trunk area ?
    This is before the restoration so cant check where the wire originates ?
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    As Scott said,,,it goes to the master cylinder switch.
    Oct 2010
    Southern Ca.
    It goes to the master cylinder imbalance switch . Comes from the trunk area and connects to the E-brake light . The imbalance switch provides a ground for the E-brake light as does the E-brake handle .
    Thanks guys , appreciate input
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
