Results 1 to 10 of 13
Thread: Best distributor/coil for 2.5
    Guys
    Building a 2.5 with DC 30 cams and Italian webers that Paul restored and tweaked for engine.
    What’s best solution for the distributor ( not for racing ) but able to be tuned for max performance.
    Also whats best solution for coil.
    Not interested in the 123 ignition
    Thanks for ideas/recommendations
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    60 Lancia Appia Zagato GTE
    Nov 2003
    Santa Monica CA
    Hi frank-- what engine configuration are you running for a 2.5 I am thinking for me it would be 70.4 crank with 86mm pistons. what say you? chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Any reason you don't want to use the stock ignition pieces?
    Guys
    Am using 70.4 crank and LN 87.5 cylinders with CP pistons
    Its been suggested I have a distributor that can be recurved also seems many strongly suggesting
    123 Ignition
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    May 2006
    CT
    Hi Frank
    The 2.5 (70.4x86) I built for last year uses a rebuilt 2.2 distributor with the PatsKlassic coil and Bosch CDI. Seems to run just fine.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Mar 2017
    Orange County, CA & Tucson, AZ
    Quote Originally Posted by 71gold View Post
    Guys
    123 Ignition
    I have almost the same specs as you, just using JE pistons. I am at 9.5:1. I built my 2.5 out of my 2.4 motor. I used the stock 2.4 distributor, with an S rotor (curves were same for S, T, E for the 2.4) - rotors were different to allow for different redline. I absolutely love my 2.5 - I debated the DC30 vs the DC40 a lot and am extremely happy with the DC30. Also using stock ignition (coil and Ashlock rebuilt CDI).
    Bill
    Early 911S Registry Member #4087
    Instagram: @myflat6
    '72T hotrod 210 0228
    '82SC Targa
    '97C4S (sold - and regretting it)
    Apr 2004
    35,000 ft
    Quote Originally Posted by tom1394racing View Post
    Hi Frank
    I've tried the PartsKlassic coils and had 2 coils fail.
    Guys
    Spoke with Henry @Supertech mostly on The bird …he suggested the 123ignition and after some additional research am really Starting to like the setup. Has great reviews works with 3 pin CDI and can be tuned ( with phone ,notepad etc) to best suite engine variables.Anyone here using?
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
    Thats fine that its tunable,,,,how will you determine what that is? Chassis dyno ?
    Ed
    Your correct….have not seen a dyno graph published.
    As I am more old school can’t quite fully commit to 123ignition
    Have you done any evaluation on this setup ?
    Frank
    73.5 Snrf T
    71 Snrf T
    70S targa
    76 914 2.0
    82 Targa,
    85 Alfa GTV6
